MrAl
Hello,
Here's a pretty simple power supply that can also charge
batteries and work as a constant current source for many
of your testing needs. Depending on what resistors you
connect to the terminal strip, you either get a
1. Voltage regulator
2. Current regulator
3. Li-ion battery charger (up to 1.5 amps)
4. NiMH batt charger (if you're willing to watch for -dV)
This could have been called
"Power Supply on a Terminal Strip"
With the terminals strip, you can connect any kind of
resistors you need to configure the ps any way you need.
To run as voltage regulator alone, connect
Rvs, RCL, and 220 ohm resistor. RCL sets current limit.
To run as constant current supply, short RCL and connect
RCC and dont connect Rvs.
This will also charge NiMH cells if you watch for
the minus delta V with a meter.
To charge Li-ion cell, use Rvs, RCL, and 220 resistor.
Set Vout with pot to 4.15 volts, then connect cell.
RCL limits max current for your cell, depending on
what kind of cell it is.
Heat sink should be large enough so the LM317 doesnt
go into thermal overload with high input voltage
and low output voltage and high current.
I used a heat sink with many fins, size 3x3x1.5 inches.
I actually built and tested this with the terminal
strip, and i can tell you it's the most versatile
power supply i've ever had.
The terminal strip i used only had one screw per position,
but you can get the type with two screws per position to
set this up without having to solder anything to the
terminal strip.
I used a 10 turn pot but you can use almost anything
from about 1k to 5k. The 1k 10turn pot gives nicer
voltage adjustment.
Take care,
Al
terminal strip.
voltage adjustment.
Take care,
Al
