Re: How to get rid of cigarette smell in new condo
start smoking, you'll probably wont notice it after a while. hehehe just kidding. If you haven't tried already, the walls may need deodorizing : 1 Tbs baking soda + 1 tsp lemon juice to 2 cups hot tap water in a spray bottle. Keep on as long as the paint/wall paper doesn't get ruined (test in a hidden area). You can also deodorize with 1/4 cup baking soda (Arm & Hammer is o.k. - I get them in a large 10+ lb box)in hot tap water in a 2- gallon bucket and sponge on lightly. This much will clog a nozzle in a bottle.
I assume you've steam-cleaned & shampooed the carpet and upholstery. If not, or you can't afford it, you could sprinkle baking soda all over the carpets and leave overnight. Next, shampoo carpets and upholstry with: a 1/4 cup of a vegetable-oil- based liquid soap (i.e from Trader Joe's or any natural grocery store), and 5 gallons of water. Adjust depending on the volume taken by the shampooing machine you rent. If you decide to add some essence in the water (usually oil-based), beware not to add more than a 1/4 tsp. to 5 gallons of water, since oil will bind with the soap, making the soap less effective in solubilizing other oily substances in the carpet and removing it. Depending on the hardness of your water, if you get too much foam, decrease the amount of liquid soap or add a bit more of the essence based in oil. Next load of hot water, add less soap. If you want the convenience of a prepared bottle, you can purchase from Grany's at 818-577-1825 orAFM at 1-909-781-6860. Both in CA
For air deodorizing, try bowls of baking soda in several areas of the room or bowls of vinegar, or bags or zeolite, a natural mineral found near volcanoes. Get it from Dasun Company 1-800- 433-8929.
