I got a Canon Optima 20 and brought it back to the store because once I saw the reds on the TV they just looked too washed out. I don't exactly have spare cash these days (far from it) but I've got 3 boys 5 & under and think about this as my only chance to catch them at this age on film. So I splurged.
I exchanged that version for the Optima Xi and it's far, far better. My wife noticed the difference too.
Be forewarned that NONE of the digital camcorders below the 3-ccd versions capture dim lighting like the old hi-8 could. They basically just all suck in "low light", which means everything indoors, but this Canon is one of the better ones.
I was very happy to have bought mine from a reputable brick & mortar shop that would let me bring back what I'd bought initially until I got it right. They even offered to lend (not rent) me a hi-8 camcorder to transfer my old tapes to digital.
And then there's the FireWire digital output... I had been using a dual-Xeon Windows 2000 / RedHat box but could never get anything but stills out of the camera without needing to buy more software or spend hours editing the film. Hours I do not have. Then for work I bought an Apple PowerBook G4. Holy crud what an easy thing it is getting the movie material out of the camera and pasting the pieces together. I even added some fades etc. It must have taken me like 1/2 hr at the most from start to finish including learning iMovie. So... I guess what I'm saying is that if you get a digital camcorder you should also not forget that you'll probably want to put the stuff onto a DVD and if you do that you'll probably want to do at least SOME editing. Think about that as an accessory you'll need too, whether it's Wintel, Open Source, or part of iLife.
Some pro's:
- Super easy to use, just point & shoot (mostly; see light color below)
- small. It feels smaller than my old Sony Hi-8 camcorder which I thought was small.
- Direct FireWire output.
- Can plug in your old analog camcorder and use this to transfer to digital to your PC. (!!!)
- It can take decent still pictures onto a flash card. This is great and it also means you don't have to bring a digital still snapshot camera with you if you don't mind the lower resolution. (2 Mega pix I believe, which is pretty darned good for a digicam and all you'll need for a huge pic)
Some con's:
- There's no button for the color temp, or whatever that's called. It's buried in the menu for the camera settings. When I'm inside I almost always need to manually set the color temp to get the whites to look white (a bubble bath shouldn't look like the bubbles are sea foam crud)
- It has a battery saver mode that shuts down the camera if not used for some time. This cannot be altered. The problem is that many times I've been holding the camcorder for a bit just waiting for that "right moment" then when it comes I get a blinking warning that the camera's about to shut down. No button pressing can bypass this so I need to fully shut off the camera then turn it back on and wait for it to go through its startup self-test whatever before I can record. By then the moment is always gone.
- You'll definitely need another, bigger battery and you'll want to get a monsterous flash card. You can only get something like 4 pictures onto the included card.
Happy hunting, and... CONGRATULATIONS on the reason for needing the camera in the first place!!! /ubbthreads/images/graemlins/smile.gif
