I have had the same problem with my AAA PE since I bought it (bought it used on ebay) a couple months ago. I am hoping someone can help with a DIY solution. You turn it on then you turn it off... everything is fine so far... then you try to turn it on again and nothing... won't come on. So you loosen it a little more then tighten to the on position and still nothing... then you loosen some more and then retighten and still nothing ... then you loosen some more and retighten and then a little more and more etc etc and still nothing. You end up having to loosen the top to the point that it is completely removed from the rest of the light or comes very very close to being removed from the rest of the light, then you can screw it back down to the on position and it "may" come back on. Sometimes it take several trys to make it come back on. /ubbthreads/images/graemlins/frown.gif Please help. Thanks!
