Robocop
Moderator, *Mammoth Killer*
I have recently received 2 extra Arc LS lights on a trade.One is fine with a nice beam however the other has a weird problem with the optic.When lit exactly half of the beam is a hazy gray color and the other half is clear and bright.I am not really sure if the problem is in the optic or the emitter.Is it possible for one half of the emitter to go bad thus causing the semi circle of brightness I see.I do know that this light once worked fine and had a complete corona of bright light and suddenly went to only half of a bright corona.
I have decided to try and remove the internals and maybe try some modding of my own at a later time.I have searched and can not find much information on removal of the factory board other than it usually has to be heated.Can anyone tell me what the tool is called that fits the lock ring and also what is the best or damage free way to heat this light to easily remove the retaining ring?
I have read some threads where people place other bezels inside a bag and boil it...will this work on the LS?..My plan for later may be to wait for the very cool kit that CY is working on to make this light modular.I am basically wondering just how bad can I mess this up if the light is already broken???
