the z49 is the one i m getting... it looks promising... Anyway i found my e2d clicky getting pretty easy to get stuck in the on mode.... i poured oil inside the tailcap and knowtised oil stains on the other side(the outside of the torch) near the rubber... i used a jack knife to move the washer like thing and found that its loose! i immediately tightened it well and fix the clicky with grease and it all worked out well...
Then i went home from camp and pressure test it at 35PSI and vuala!!! NO LEAKS! i m so damn happy man... i remembered when i 1st bought and tested it, it can take it but my results are not reliable that time so when it leaked a few days ago, i assumed it cannot take it in the 1st place... if only i got a better way to pressure test it, i can bring it up to 45PSI
