The Fenix-Store
Results 1 to 12 of 12
Thread: What is your favoite Mini-Mag led replacement bulb
    Default What is your favoite Mini-Mag led replacement bulb
    Mine is the Tektite LT-1
    The LT-1 will last 15 hours in the Mini-Mag. No modification is need to the Mini-Mag or reflector. It is truly a drop in led replacement bulb. The same led LT-1 fits the Mini-Mag 2xaa and the Mini-Mag 2xaaa without any modification. The LT-1 is a ground down Nichia led that acts like a side emitter led making use of the reflector to focus the beam.
    What is your favorite Mini-Mag led replacement and why?
    Thanks
    led_replacement
    http://www.led-replacement.com/LT-1.html [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Flashaholic* Schuey2002's Avatar
    Sep 2003
    Out West
    Default Re: What is your favoite Mini-Mag led replacement bulb
    Mine is the the Lambda 3W High dome Super Pill.
    Why? 'Cause it is bloody awesome!! It's white, bright, has excellent side spill, and throws pretty far for something that uses such a small reflector. All this goodness come in the form of a little package that just plops right into stock mini mag.
    Did I mention that it is awesome??!! [img]/ubbthreads/images/graemlins/nana.gif[/img]
    Jun 2003
    Minnesota
    BB750 Lux3 TVOK
    *Flashaholic* PlayboyJoeShmoe's Avatar
    Sep 2002
    Shepherd, TX (where dat?)
    For general utility use (close up) I think nothing beats the Opalec Newbeam!
    Overall, the Lambda 3W High Dome Drop in pill (HDDIP).
    As mentioned above it is bloody AWESOME!!! And it can be defocused to a wide flood for close work. Only drawback (which is where the Newbeam shines!) is about 2hr. runtime. (Opalec has 10).
    Dec 2002
    Tennessee., USA
    Not to change this thread, but why does this 3 watt drop in run for two hours, and the Streamlight one watt only run for one hour, and change.
    Sep 2002
    All I can figure is that they drive the everyliving SNOT out of the 1W in the Streamlight.
    To be somewhat fair, I think 1 hour is on alk. A couple of NimH should go 1.5 or a bit more.
    And the Lambda probably won't do 2 hours on alk.
    And besides, at the kind of use I and many of us do (minutes at a time and not more than 20-30 minutes in a day) we are talking a pretty long time on a set of batteries.
    And I would ALWAYS use NimH... runs for free! And I keep some charged ones in my truck because my CD Player runs 'em too.
    Flashaholic pianoman's Avatar
    Jan 2004
    CT
    Go sandwich shoppe GO [img]/ubbthreads/images/graemlins/happy14.gif[/img]
    Sep 2002
    My only gripe with sandwiches is (well two really)...
    The pink/purple tint of the two Madmax I've seen, and being locked into using an optic.
    I haven't been to the shoppe lately, so I might be talking out of my A$$...
    But having seen a 3W driven at 600ma through a reflector, I have seen perfection!
    Sep 2004
    I may look into something like that. Got 3 mag lites laying around.
    Jan 2004
    Oregon
    Question about the LT-1. Is it about the same as the old Infinity, lumen wise, spill wise, ect.
    Flashaholic* Krit's Avatar
    Dec 2003
    Thailand
    Miniprolight engine of lambda with luxeon III. It can use both 1 AA and 2AA cell. Although the battery is seem to be empty it can make a useful light. or you cam get the SMD+ with the bright with reasonal cheap price.
    Nov 2002
    The South
    My favorite drop-in replacement for the Mini-Mag is the Streamlight Jr. Luxeon. It doesn't just replace the bulb, but is a drop-in for the entire flashlight. It is also available at an economical price compared to most other drop-ins for the MiniMag.
