[ QUOTE ]
tylerdurden said:
Nice. That's just a standard ecan? What material are you using for the isolator between the ecan and the screw?
I was thinking about ways to do this just recently. The best idea I came up with was to fill the bottom of the ecan with playdoh, just barely, so that the inside of the lip is flush with the playdoh, then fill the can halfway full with Arctic Alumina. Once it dries, you could drive a screw through the AA, trim as needed, and then solder the wire to the bit of screw remaining.
[/ QUOTE ]
I built a 5W Mclux PR head DD a while back using the contact assy from a standard McLux head. There are some pictures
here.
The trick is you must flip the cathode contact "ring", as seen in the pic in the post I linked, when installing it as opposed to how it's supposed to sit in a standard McLux head. It's hard to see it but in the pic of the cathode contact "ring", I cut a groove for the positive wire so that it will line up directly with the hole in the head. I also did this for the negative wire and filled it in with solder. That way the cathode contact "ring" will rest flat all they way in the head.
