Foam Donut for the AAA? (adhesive and foam source)
Status
Not open for further replies.
GarageBoy
Brooklyn NY
I removed the foam donut form the arc for redo the solder blob with some silver solder.(I flattened it out) The donut is a bit flat too and it keeps falling out. Where do I get a replacement and the glue?
Gransee
Mesa, AZ. USA
This has been covered several times here. You can use the foam from Dr. Scholls foot pads. The adhiesive is Pressure Sensitive (PSA). You could use some contact cement. It is tricky since not many things stick to silicone.
Peter
Status
