[ QUOTE ]
PlayboyJoeShmoe said:
_
___/
______/
______
\___
\_
Body^ ^Switch Housing
^ Bezel
I traded my Stinger HP off for the standard Stinger which has a much more useful beam.
My guess and recollection about the HP is that the "body" is very close to the same UP TO the switch housing which is bigger. And nearly the same from that point to the head.
As there is an HP kit you can buy to upgrade a standard Stinger, my guess is it doesn't add all that much length, but does get a much bigger head/bezel.
The body is 1 1/16" diameter, not 1". The switch housing is 1 1/2". Bezel is about 1 5/8".
The way my Stinger fits in the Garrity Holster, it stops just at the switch housing. I feel that if the holster was any larger diameter, it would be sloppy and less secure.
I still don't understand exactly what you are looking for. But I hope this helps!
[/ QUOTE ]
I want another RipOff pouch for the light I have which is the Aleph 3 in this picture but is going to have a 4x123 battery tube.
A RipOff CO-31 works with the 2x123 tube but I need a longer pouch for the 4x123(ordered), so I'm trying to use "any" factory made light that may be listed in the RipOff catalog to compare with. The Stinger might have a bit larger battery tube but this pouch will have a flap anyway. Follow my thinking yet?
