The LightPipe has been reborn!
For those that don't remember, the LightPipe was a project I initially completed in July. It was a 35W, 10 degree MR-16 bulb fed by a 10 cell SC NiMH pack, built in a piece of 2" PVC tubing.
Here is the original sitting beside a 2D MagLite:
The original was 12" long, made from black plastic that had a tendency to melt and smoke after running for about 5 minutes /ubbthreads/images/graemlins/eek.gif
I finally got around to ordering some aluminium tubing and other metals to re-create this beast in a form that wouldn't melt down in short order.
After hours of filing, cutting, drilling, tapping, and some swearing, here is the result (sitting next to a 2D blue MagLite):
My least favorite part is the clips that are holding on the endcaps. I was hoping to put screws into the end of the tube, but it wasn't thick enough (1/8" wall thickness), and a 3/16" wall thickness tube cost twice as much, so this will do.
It's now only 8.5" long, instead of 12, so it's easier to handle. The i.d. of the tube is now 2.25" instead of 2", so I was able to fold the battery pack in half (so it's a 2x2 cluster, instead of a straight 2x1 stick) making it over 2" shorter. I can't even tell that the tube is any larger.
Beamshots are identical to the previous incarnation, here's a refresher:
(5W VV0S@750mA in a Mag 2D on the left, LightPipe on the right, shots of my garage)
Can't wait to take this thing for a walk tonight...should light up the park quite nicely /ubbthreads/images/graemlins/grin.gif
