geepondy
Picked this up at the local (Burlington MA) EMS for $32. There are four left on the shelf.
Ok, first and foremost it is definitely a Luxeon. I don't see any "special optics" though just a piece of plastic covering the standard Luxeon collimator. It has an aluminum body with a plastic, excuse me "polycarbonate" head. While not horrible, the fit and finish is not near that of the Arc or Surefire. You feed the batteries by untwisting a tail piece, easy enough to do. The body is about the same size as the Arc LS 2AA body but the head is much longer and somewhat wider then the Arc. My biggest disappointment thus far is the switching mechanism. It is a rotary type of switch that you activate by turning the head. On again, off again and repeating itself continuously each quarter turn or so and is bi-directional. The problem is there is no locking mechanism either off or on and it is much easier to leave the light in the on position then in the off position. If this was to jostle around in a backpack or in a similar environment, it could very easily turn itself on. I like real switches but in this case I would much prefer a regular Arc style of tightening the head to turn in on. I have just now found a way to create a lockout of sorts. If you loosen up the battery retainer tailpiece by half a turn or so, it effectively locks out the light from engaging. Even shaking it vigorously does not make it illuminate so this may be an effective workaround. Also there still isn't any battery rattle when doing this.
Now about the beam. I loaded both it and the Arc LS with reasonably fresh lithiums batteries and did a comparison. Surprisingly they were very close in brightness. I have an original Arc LS, run #10, and I now know that it is one of the violet Luxeons. The Reactor color is more white in the center but has a very greenish corona. Is this what people are talking about when they mentioned the pea green Luxeons? The characteristics of the beams from both lights are fairly similar to each other. The Arc may have a slightly more tighter hotspot while the Reactor has a slightly more wider hotspot but very close just the same. The Reactor LED is much more centered then that of the Arc LS. I cannot tell if the optics of the Reactor are the new style or old style as there is a plastic lens protector covering them.
Well that's it in a nutshell. I consider it a good value for the money and would consider it a very good value if it had a better switching mechanism. I can try to answer questions people might have.
