Is this do-able? I assume with a big enough resistor, it should be. How much heat sinking would it need? It would be placed on a 2"X 2" aluminum plate. Is that enough heat sink?
To drive it at spec 350mA, you'd need a 5 watt resistor around 25 ohms with its own separate heatsink, and a heatsink for the Luxeon. The 2x2" plate sounds adequate, get one for the resistor and one for the Luxeon.
Personally, I'd use an LM317 in current mode. You need a 3.6 ohm 1W resistor and the LM317. Use separate 2"x2" plates for the '317 and the luxeon. (The '317 will need some heatsinking by its self).
If you worry about cost then get George80's dome light but personally I would use an nFlex with couple Lux3 from oo2oo (<$15/each). Who cares about heat and efficiency when you got an alternator and 3000 lbs of heat sink /ubbthreads/images/graemlins/wink.gif
