This may be a stupid question, but I was wondering if they made a double ended flashlight? One end a bright xenon light the other a 5 watt or higher led light? Sure I have seen the a2 by surefire and a few dual mode they had in the cabelas catalog, but they are either too dim or too big.
The close as I can figure is to get a surefire with a xenon head and led one. Assuming they make a bright led head and just swap them as needed, assuming they can be swapped. Sorry, I have no experience with surefure.
Design wise, I guess we could just use a threaded piece of pipe or so for room for 3 cr 123 cells, clickie switch at both ends, screw on heads at either end, one 5 watt led or brighter, other xenon. Then the clickie switchs could be 3 position or so, maybe a toggle switch in this case. One position is open, one is to light the head near it the third is to close the circuit for using the other end of the light.
I do see if they switches are in the wrong position it wont light, short out or both ends will light. Of course one end would need a cross over for the polarity difference.
Does this exist? Is it not worth making? Does the surefire swappable heads work better?
Just wondering
Just wondering
