Streak
The Micra seems to have a Kroll switch much the same as the original ARC LS just with a different rubber boot.
As you turn on the unit or fiddle with the pushbutton while it is one the light flickers somewhat. In fact I dont believe that I am getting full brightness out of the light.
I am pretty sure the problem is continuity in the switch. I see that the switch has a couple of springs, a washer and other bits and pieces. Where can I tweak to improve continuity and maximum voltage to the LS?
TIA
Streak
TIA
Streak
