Northernflame
- Joined
- Sep 23, 2004
- Messages
- 145
Hi.
Some one probably came up with this before . However it's worth mentioning.
For those that have led flashlights with no reflectors (like Lightwave 2000 or 4000.Where the led's stick out of the head.
Here's a simple trick.
Get a piece of aluminum pipe or abs plastic pipe that fits well (snugly over the led (head) end of the flashlight. Measure and cut either a 1 inch or 1.5 inch piece of the pipe (+ the lenth that fits over the flashlight led's/body. Like putting a smaller pipe (flashlight) into a larger pipe.
After you've cut the proper length . If it's ABS your already done as abs plastic pipe is already somewhat polished.
If you've chose an aluminum pipe then find some nice 800 gritt emery cloth and rub polish & clean out the inside of the aluminum pipe then put it back on the flashlight.
This has a nice way of smoothing out a beam.
This trick will not work with flashlights with reflectors or colimnator lenses.
Enjoy.
Enjoy.
