It's not quite that simple. R123s and CR123s are not replaceable 1 for 1. The voltage coming off a CR123 is pretty much 3V, whereas the voltage from a R123 is anywhere from 3.8 to 4.1 or so. If you put a R123 in a SL TT 1-L, there's a good chance you'll give something in there a really bad day (i.e. cook something).
The SL TL-3 is a 9V rig so you might be able to use 2 R123s with a dummy battery spacer. The voltage in that case would be under 9V and the bulb would live to shine another day. It would be around 8.something which is good enough to run most 9V bulbs. I haven't tried this combo, but in theory it should be okay.
The SF 6P is a different matter. The P60/P61 LA in it is intended for 6 volts. With the Surefire you can do one of two things. The first would be to get a Pila 3.7V LA, trim the spring, a use 1 R123 with a dummy battery spacer. The second and probably more fun choice would be to use 2 R123s and get a P90 LA. Don't even think about a P91 the protection circuit in the R123 cells won't allow it to happen.
Hope this answers your question. If not, hop over to the search page and there are plenty of other threads with the same questions.
