Re: Luxeon bulb replacement for Maglite Rechargeab
[ QUOTE ]
gewe said:
That's not really what I am looking for. I want at least the same amount of light as with the standard bulb, with longer battery runtime, and longer lamp life.
[/ QUOTE ]
If you can build your own pack, you can get 5 aero 4AH NiMH which will almost double your battery life with the stock bulb. You can pick up WA01160s from flashlightlens.com for about $5 each. With the greater current of the 1160, you'll get about 50% better battery life with a nimh pack than a stock bulb with a stock pack. This setup will yield about 500 lumens and cost less than a single luxV emitter, which will yield about 120 lumens.
[ QUOTE ]
I already have a Maglite Rechargeable, so this is not an option for me.
[/ QUOTE ]
Getting a 2D or 3D Maglite host would add about $20 to the cost of whatever you choose to do. Given the relative cost of the Magcharger ($100) and the parts to do a LuxV mod (!$65), this isn't very signficant.
For a LuxV (5 watts, 120 lumens) mod, you're going to need an O-sink or a Hotlips for about $15 then you'll need an emitter, which will set you back about $30 or more, if you can find one. Then, if you want to do a current regulated setup, which I would prefer, that'll set you back another $15-20. On top of that, the 2-piece reflector assembly in a Magcharger is setup such that it'd be difficult to modify to fit around an O-sink or a hotlips.
