elektrofreq
- Joined
- Nov 11, 2004
- Messages
- 9
Hello,
Im trying to set up an RGB led light. Ive got luxeon led's, Led Dynamics Buck Puck luxeon drivers, and a PWM circuit I built.
The PWM circuit is a 74hc14 set up as an oscillator (four oscillators, really. one fast for pwm, and three for automatic slow fading of 3 channels) and an lm324 comparitor to make the square wave pwm..
The circuit works great for lighting regular led's. Full control from full off to full bright.
The luxeon drivers I have, have an output pin that puts out 5v, and an input pin. at 0volts on the input the led is full bright, at 5 volts the led is off.
I hooked my pwm circuit to the 5v, but the circuit takes away about 1 volt, so the output isn't quite enough to give full control of my luxeon driver.
SO, I decided to use a transistor. I figure'd I'd put the output of my pwm to the base, and have the transistor pass the 5 volts to my luxeon driver.
I thought this would be simple, but just can't get it to work.
The problem I am having is that the luxeon never goes all the way out, and never goes to full power. I've tried every transistor I can find. npn, pnp 2907 2904 4403 4401 3702 3904 etc etc etc..... and they all do the exact same thing. Ive put a resistor in line w/ the base, and got the luxeon to go all the way out, but when it should have been fully bright, it was just barely lit.
I have read every PWM schematic I can find on the web, and they are all basically the same.. the pwm drives an output transistor/mosfet or something, and that drives the light or motor or whatever. I can't figure out where Im going wrong.
Any help would be greatly appreciated!
