Likebright
For the past two or three months I have been using my Elektro Lumens TryStar Phazer with the Pila168s rechargeable batteries. The three emitters seem to be able to handle the increase in power alright and they burn much brighter than with the 4 C cells. I have put a spacer in the middle and use the hose to adapt the size of the batteries to the light.
I get about 30 minutes continuous run time at which time the light shuts off. Much more run time if intermittently used. It is good for around the house and seems to stay just about as bright right up till it kills. Then I just charge up the batteries. /ubbthreads/images/graemlins/smile.gif
The increase of brightness and recharability is well worth the short run time if you've got a backup light to get you back to your charger.
You can always switch back to the C cells at any time.
Mike
Mike
