I just received my order from LSDiodes for a few 3 and 5mm LEDs. I took a 3mm white LED, cut the leads down to match the bulb and plugged it into a M-glite 2AAA. The 3mm led fit the reflector fine and it turns on and off as it should. The output with alkalines is less than an Arc AAA standard white but usable as an emergency type light.
1. Is direct driving the LED pulling too much current?
2. Could I put a resistor in the tailcap to drop it down?
I am going to try a similar mod with a 3mm amber LED in a Solitaire. If it doesn't burn up I may make a few to give away as gifts. Has anyone tried this with amber or red LEDs?
