Re: Arc 4 and rechargeable 123\'s?
I do use unprotected cells a lot in my Arc4 (Rev1), two different ones (altough they both may be GreatTech) and have no problems with them.
Using 'protected' cells in an Arc4 is not necessary and works a little bit against the phylosophy.
The Arc4 takes very well care about that and you have some warning before the cell gets empty.
Cy thankfully told us that the protection works only when you put in a fully charged cell and you do not remove it until you recharge it.
The same is, when your cell is too short, as it may interrupt the circuit sometimes.
If you don't have these issues (like me and all the other Arc4 owner I know), it works perfectly.
A protected cell protects itself very well, but not the user. In case of emergency, you may end with no light without any warning. If you are using your Arc4 for not so critical tasks, protected cells will do fine.
Tom: look at the list about your specific light's the current draw for 3V and calculate it for the input voltage you want (not perfectly true, as the efficiency changes, but should givve an idea). If you want to guestimate it for 3.6V (20% more voltage), just multiply the cureent given with 0.83.
As I posted on several other occasions, I get 40 minutes (continuous) runtime on highest level with one of my better R123 , but also the other is at 38 min not far behind.
