Your battery is almost depleted. If you replace the battery, you will be able to switch from the high to low again.
The low beam of the L1 is not regulated, and do not come up when the voltage of the battery is too low. The same voltage can light the LED trough the voltage converter, in high beam mode, for hours.
IMO, it is the only "fault" of this wonderful light.
Anthony
