My car tale of woe this year...sorry can't resist posting!
I know nothing about engine repair so other then changing the oil which I haven't done in 15 years I am at the mercy of the serviceman for whatever my needs.
I had a 1998 Subaru Impreza Outback. This Spring I had the clutch replaced at the dealer for a quoted price of $900. While on the lift, the dealer called and said there were several oil leaks going on including one at the oil pump and part of the exhaust was gone. Also he said while changing the oil pump, you might as well replace a couple of belts as it will be parts cost only. So I okayed everything and my $900 became $1700. Shortly after that, the knock sensor went bad and I had the AC recharged. Tack on another $200. Then in July I had four new tires installed for $340. That was a tough call but I figured I'd spent this much on the car already and I really did want to drive it for a couple more years so now I would no longer have to worry about tires. At the end of the summer I heard that old familiar whine starting in the right rear which I know from experiences twice before, the wheel bearing was on it's way out. But I never got to the point of replacing it. Shortly after that, my timing belt snapped, later determined to be caused by a bad idler pulley that froze. There was all kinds of hairy damage in that area. $700 later, the car was at the point where it could be started again. That's when we found out two cylinders had zero compression. An estimation was given of possibly up to two thousand dollars to have it fixed. This was at a little local garage and while the guy was honest, he definitely had the back yard mechanic mentality as I have been told since that before I put $700 into having the timing belt, pulley area repaired, they could have done a leakage test and found out the cylinders were bad. But I said enough was enough and washed my hands of that car after more then $3k repairs in five months time. I did get $500 when I sold it to salvage. So now I drive a used 2002 Saturn SL1. It's an ok car but the gears whine terribly and there is a constant whine at highway speeds. Regardless I just hope to get three years trouble free service out of it as that is what I took the small loan out for. So in a nutshell sure wish I was good at repairing cars. Or I had enough money so it didn't matter. Oh well...
