I`ve got one, but just the plain light without the charger/batteries. It takes 4AAs of any kind, and I don`t see why NiMHs wouldn`t work in there just fine. Unfortunately all I have round here are some ancient NiCds and half-empty Energizers so I can`t test that bit I`m afraid.
I thought the same as you when I saw it- great features. And sure, it is well made, it feels very solid, everything`s o-ring sealed so it doesn`t leak, it`s nice and compact and the built in pocket clip is handy and feels reasonably strong. It also came with a handy attachment plate that could fix to a helmet, strap or wall- so that`s where I keep mine, just over there (points to it
But.....the beam is crappy. The main bulb is quite bright but is very irregular and distorted even at the narrowest focus. At wider focusses it makes a Mag-lite look like a SureFire
The LED is also quite dim and its beam isn`t very smooth either- a little 5mm amber Toshiba one with a resistor that runs it at a lower current than most amber LED torches. It`s the same LED as in the amber Stylus-2 but less than half as bright. It is not meant to be a searchlight on its own though- the LED is intended as a backup/marker light with a very long burn time (about 3 days) and does that job quite well.
If you wanted to beef it up, the LED can be removed (it just plugs in like the main bulb)and it would be easilly possible to make a similar replacement with an LED/resistor combination of your choice. I havn`t tried it but expect everyone`s favourite Nichia model would work quite well. Don`t forget the resistor though as it`s all-plastic so a vastly overdriven LED would overheat quite quickly I expect.
Hold up, I`ll see if I have any beam photos handy......
...OK you can see 3 beam shots on my preliminary-page about it here...
http://electriclights.tripod.com/flashlights/syclone.htm . I can`t hotlink them from that page directly here sorry, Tripod blocks that as I mentioned elsewhere, a while ago.
If they worked on that beam quality issue (faceted/"orange-peel" reflector maybe) it would be a great little light, and the combination of bright bulb and LED backup is unique and useful, but as it stands, it`s nice, but impaired by that drunken spider-web pattern it projects.
