jtr1962
I recently obtained a loaner KL4 bezel courtesy of luxlover in order to examine it and run some efficiency tests. I think the results may be of general interest.
I used a variable voltage, current limiting power supply with digital readout which I built myself for the tests. The current limit was set high enough so as not to interfere with the results of the test. I measured the input voltage directly at the battery contacts on the bezel with a multimeter because of ohmic losses in the test leads connecting the bezel to the power supply. I read the current draw directly off my power supply meter. In order to measure the current draw of the Luxeon V emitter I disassembled the bezel, disconnected one of the wires going from the regulator board to the Luxeon, and temporarily soldered an 0.1 ohm, 1% power resistor in series with the Luxeon. This only added about 0.065V, or roughly 1%, to the total output voltage. Although the Luxeon emitter quickly heated up due to the small heat sink it was on, I tried to obtain some consistency by keeping the power on periods to just a few seconds, and letting everything cool for a minute or two between tests. The circuit was in regulation at 3 volts and above. When it was in regulation the Luxeon current was 635 mA and the output voltage (including the drop across the 0.1 ohm resistor) was 6.32V. Therefore, the output power was always 4.01W whenever the circuit was in regulation. The Vf of the Luxeon V emitter itself was about 6.25V, meaning that it is probably S bin with regards to Vf.
Here are my results:
Vin=3.00V
Iin=1.78A
Pin=5.34W
efficiency=75.1%
Vin=4.00V
Iin=1.23A
Pin=4.92W
efficiency=81.5%
Vin=5.00V
Iin=0.96A
Pin=4.80W
efficiency=83.5%
Vin=6.00V
Iin=0.77A
Pin=4.62W
efficiency=86.8%
Vin=7.00V
Iin=0.63A
Pin=4.41W
efficiency=90.9%
I didn't go above 7V input because I didn't have the parts on hand to repair the regualator board if I damaged it. Also, if it is like many step up circuits it will go to direct drive once Vin gets much above the Luxeon's Vf.
In typical step-up regulator fashion the efficiency gets much better as Vin increases due to the smaller input currents that the MOSFET and inductor must deal with. Although it appears that the regulator board will work in both one and two cell configurations, it will likely be out of regulation for a good portion of the time in a one cell unit. The fact that it operates down to about 2.65V means it can literally suck a 2-cell configuration dry. Efficiency at 6V isn't bad. I suspect by maybe using a slightly larger inductor and MOSFET this can be brought up into at least the low 90s.
Output on my lux meter was 1000 lux or a bit under @ 1 meter once the bezel was reassembled. The readings prior to disassembly were the same.
Vin=3.00V
Iin=1.78A
Pin=5.34W
efficiency=75.1%
Vin=4.00V
Iin=1.23A
Pin=4.92W
efficiency=81.5%
Vin=5.00V
Iin=0.96A
Pin=4.80W
efficiency=83.5%
Vin=6.00V
Iin=0.77A
Pin=4.62W
efficiency=86.8%
Vin=7.00V
Iin=0.63A
Pin=4.41W
efficiency=90.9%
