Jefff
Anyone ever had a chance to see one of these in person?
******************PentagonLight L4 5W Luxeon Light*****************
PentagonLight(tm) Professional Flashlights
..From what I have read on the website It sounds like a bad Mama Jama!!!! And judging based from the quality and beam throw of my PentagonLight X2, HA type III, Im sure it would be nothing less. But I can't seem to find anything on them other than the web site post and I guess they are out of stock at this time... just wondering if anyone already had a chance to see or use one could tell me..
Check this out.
"Features"
* 5W Luxeon white light source
* Aerospace-Grade Aluminum Body
* Momentary/Constant On/Off Tail Switch
* Double O-Ring Sealing
"L4 5W Luxeon Light Specs"
Brightness: 90 Lumens
Run-Time: 120 Minutes (Peak)
Batteries: Four CR-123A
Bezel Size: 1.5" or 1.75"
"Description"
PentagonLight L4 is fitted with our proprietary reflector designed for focusing the light generated by the 5W Luxeon light source into a smooth intensified light beam. Luxeon is power efficient and does not need frequent lamp replacement since it will not burn out like the filament of incandescent bulbs. A twist for constant-on and a push for momentary-on PentagonLight signature switch is featured. The pentagon shape tail cap makes it easy for one-hand operation.
Warranty: Limited Lifetime
**And for a Incan Light this one seems even more impressive...**
********************PentagonLight X4 Xenon Light.********************
"Features"
* Xenon Gas-Filled Lamp
* Aerospace Grade Aluminum Body
"Specifications"
Brightness: ***250 Lumens***
Run-Time: ***60 Minutes***
Bezel Size: 2" or 2.5"
"Description"
A 2" Pyrex glass front lens is featured for shielding the immense heat generated by the xenon lamp. Its PentagonLight signature design with heat sinks for maintaining optimal operation temperature for maximal luminosity makes X4 Xenon the Cadillac of handheld flashlights and the envy of other top flashlight makers. To achieve the impossible, PentagonLight has gone further to created the ultimate X4M Xenon Light. This top-of-the-line product features a 2.5" bezel head housing a mega-size reflector for directing 250-lumen of photons into a straight beam of light. This powerhouse slices through the fog and lights up even the darkest night. Both heads are fitted with our proprietary reflector designed for focusing the light generated into a smooth intensified light beam. The reflector pre-focused at factory for maximal center intensity, but it can be adjusted from flood to maximal to permit additional versatility depending on your usage. A twist for constant-on and a push for momentary-on PentagonLight signature switch is featured. The pentagon shape tail cap makes it easy for one-hand operation.
Now that's what I call a Tactical Light! I can definiatly vouch for they're Product Quality and duribility and flawless Ha III coating on my X2 and for 70 lumens rating on it ouch my eyes... Tuff as a nail so far, I would depend my life on it for getting the light when and where I needed it...
Check this out.
"Features"
"Description"
"Features"
"Specifications"
"Description"
