I just finished my first real mod, I had a 4LED module from a cheap flashlight and I took the LEDs off of the board cut the board down and redid it and soldered the LEDs back to it after I ground down all the lipped edges on the bottom of all 4 LEDs. I then got a PR base from pulling a bulb apart I had no use for a PR17 and proceeded to drill a hole in the side of the bulb for wires to go out of it. My idea was an adjustable resistance 4LED bulb. I had to use a ream to hollow out the hole of the rayovac's reflector and replace the lense on the front with a piece of plastic I cut from an old CD case. I can revert the light back to original by replacing the bulb with the .75A 4.8v bulb and the lens.
Final cost: 1.09 for the light I got the LEDs from, 3.27 for the rayovac light at walmart and several hours of figuring things out.
I took the first two fuzzy pictures during construction of the bulb and wasa too tired to take more at that time, the rest I took when I was awake and made sure they were crisper although several shots I had to delete because of excess fuzziness.
The rayovac light is dark green 2x2AA format with rubber lanyard. I soldered a 10ohm resistor to the bulb but change change it easily anytime or even solder in a boost circuit or a dimming control.
I will try and take more pictures later if anyone is interested.
Here are some better pics, I am having problem with the autofocus on this borrowed toshiba 4.3mp camera.
Inside of the rayovac light.
Bulbs ready to swap.
Business end ready to go.
Finally the beam shot.
The reflector picks up a fair amount of spill causing an interesting pattern. I had to remove the orginal magnifier lens assembly because it skewed the 4 LEDs into a widening 4 seperate *splotches* of light not useful beyond about 5 feet.
It came out better than I expected and if I had new LEDS with longer leads the mod probably wouldn't have taken half as long to do. It is a nice light for under $5.00.
