toomanyleds
- Joined
- Sep 2, 2003
- Messages
- 2
I have an Inova T3 and like (or liked) it very much... EXCEPT that the switch now no longer works /ubbthreads/images/graemlins/frown.gif. It worked fine when I got it. I was showing it to someone, he unscrewed the tail to look inside, put it back together, and from then on the switch has not worked. There was absolutely no abuse to the light.
What it does now is that it will light if you press the button in hard and hold it, but it does not remain on when you let go.
I noticed in Quickbeam's review (flashlightreviews.com) that he had the opposite problem. His did not work right when he initially got it, but after unscrewing, replacing, and clicking a bunch it started working.
It seems like the switch is a little flakey and unreliable, which is sad for a tactical light of this price and otherwise fine machining.
Putting a washer in to add pressure did NOT fix it. The problem seems to be in the switch mechanism itself, not in loose batteries (there seems to be a spring mechanism in the light end that presses the batteries down).
Has anyone else encountered this problem? More importantly, has anyone else fixed this problem? If not, I guess my next call will have to be to Inova to have it replaced/repaired, unfortunately.
