greenlight
Anyone think the infinity ultra has too much glare? It's a very bright light and looking at the led is uncomfortable, so what if one wants to be able to reduce the blinding effect? What if it was more like the sonic, which had the recessed led which made it more like a stealth light?
I glow painted the bezel of my infinity. The glow is super, but the small amount that leaked down to the base of the led is the brightest. Then I thought, "How much glow polish can I add at the base of the led without sacrificing brightness?" A simple test with salt answers this question. Fill the bezel, go into a dark room (with the infinity on, obviously), and gradually blow out the salt. You will notice that the spot is unaffected, but the spill is reduced some. Then look at the glowing salt and realize that you have solved the blinding problem. The glow polish trasmits a more difuse light than the direct led, but doesn't affect the usefulness of the spot at all.
Edit: This also solves the irritating 'uncentered led' problem by difusing the corona somewhat.
