jtr1962
An interesting project was dropped into my lap today. There is great interest in replacing the fluorescent light source currently used on taxi roof advertisements with something LED-based. We (meaning myself and the person I'm doing the project with on a consulting basis) want to make something which is better than the 4-foot fluorescent tube currently used.
First, a little background. Some but not all NYC taxis have a fairly large (~4 feet long) lighted rooftop advertisement holder. Here is a general idea of what they look like although the ones in NYC are somewhat different:
Current models use a single four-foot fluorescent tube for lighting. We're considering two options to replace this light source. One consists of two strips of 100 5mm white LEDs. The other would be Luxeon-based. Since the light from LEDs can be more easily directed where needed we obviously don't need to match the fluorescent tube's output. Point of fact, I believe the tubes were somewhat underdriven anyway. Regardless of which type of LED we use, the final device must be a simple bolt in and wire-up replacement. There is also a price constraint. One competitor is already selling 100 LED strips for $65 (I think per unit, although that might actually be for two units). In any case, we're aiming for a retail price of $65 total, which means these things must cost us less than ~$45 to make.
5mm LED strips represent one option, although I personally have my doubts if two 100 LED strips would provide sufficient lighting. Also, I have a lot of concerns over lifetime. Tests a few years ago showed 5mm LEDs degrading to 50% brightness after 6000 hours. Considering that the lights will be on whenever the taxi is in use, and taxis here run about 18 hours/day, this means either unacceptable dimming after a year, or the need to overlight to compensate for the expected dimming. Does anyone here know if the lifetime problem with 5mm white LEDs has been solved yet, especially with the lower cost HK LEDs which we'll be forced to use (at $0.43 each even in large quantity Nichias are out for this project)? In the quantities I envision needing (100,000 to 1,000,000 pieces), I've seen some HK suppliers offering high-brightness white LEDs for ~$0.11 in quantities of 100K+. I think for this project wide angle (40°) LEDs will be better suited. This gives an LED cost of $22 for two 100 LED strips. Add in the PC board, electronics, mounting system, and hopefully the cost should come in at less than $45. Assembly will cost significantly more here than with something Luxeon based, but the LEDs themselves probably cost less per lumen.
The second option is Luxeons. I'm thinking perhaps 10 L3's running at 700 mA (or less) should be sufficiently bright if the light is directed properly. Does anyone have an idea of how bright (in lumens/ft²) lighting advertising signs typically are? The problem here is obviously cost per lumen. I'll need to obtain the L3s at $2 or less each in order to remain competitive but we will be using large quantities of 10,000 to 100,000. Naturally, I'd prefer T bin but I couldn't care less about tint. I'll just make sure to match tints on each unit if I get a batch with different tint bins. I heard several times on these forums that L3s can be obtained at such prices straight from the manufacturers in China or wherever but only in huge quantities. Can someone here provide me with some contacts so I can inquire about this further?
Putting aside cost, another problem arises with L3s. They need to be heatsunk which means you can't mount emitters directly on a PC board. One option here is epoxying the emitters to a four-foot long, 1 inch wide aluminum strip which is turn gets bolted to the top of the ad box. This means the need to hardwire the emitters together which will obviously increase labor costs. Another option is to have a PC board with holes where the board connects the emitters together yet still allows them to be glued to a piece of metal. Any other ideas here? Think in terms of low cost and ease of assembly. Remember that the whole thing with 10 emitters, the driving circuit, and the PC board/heatsink must come in under $45 ($50 tops) assembled or it's a nonstarter. The taxi industry doesn't care if ours is 100% better if it costs $5 more. They'll buy the competitor's cheap garbage instead. Don't worry about the electronics end-I can probably design a halfway decent step-up driver for 10 L3s in series for less than $2 in parts.
Now about driving current and lifetime. I'm not sure exactly how long this thing needs to last but I'll assume at least as long as the car, which is typically about ~5 years. This means up to 50,000 operating hours. Unless 5mm white LEDs have improved they obviously won't cut it, nor will driving the L3 at 1A. At 700mA I should just barely make the lifetime requirement but should I cut down even further just for a safety factor? I'd rather even have 15 emitters running at lower current if it means 100,000 hours lifetime, or if needed to give 50,000 hours under the adverse conditions taxis operate under.
To take this all one step further, how are blue and true green 5mm LEDs for lifetime? Another option instead of 5m whites is red, green, and blue in the proper proportions. Red obviously has no trouble reaching a 100,000 hour life but what can be expected of the other two colors? I know they'll last longer han white and probably less than red, but can I expect at least 50,000 hours to 50% brightness? RGB will allow both increased efficiency and a little less cost than whites. Color mixing should be OK due to the large numbers.
I'll be finding out some more about the project in the next few days but any help/suggestions that anyone can give me will be appreciated. I'm hopeful that the competitor's version will turn out to be so bad that the cost constraints will be relaxed a bit. Naturally we can design things optimally given enough money, but it takes really clever engineering to get things out the door super cheap. And the taxi industry is about as penny-pinching as they come.
