This looks like it might be the report you referred to-
http://www.abc-7.com/News/DIW/tekplate.shtml
"When a hurricane or even a heavy rain storm strikes, it's easy for the electricity in your home to be knocked out. If it's at night, you're stumbling over your furniture to find a flashlight or a candle.
A product called the TekPlate says it not only kicks on light when the power goes out, it's enough to light up the room. ABC7 put it to the test in this week's "Does It Work?"
**** Murno of Port Charlotte installed TekPlates over the light switches around his home. The battery operated lights are supposed to switch on when the power's out and provide enough light to illuminate an entire room.
An antenna in the TekPlate reads the electromagnetic waves behind the switchplate, so it can tell when the power is cut off.
**** then cut the power to his house to see if the TekPlates worked.
Looking around the living room, the furniture was fairly visible. **** was impressed.
"All the stuff at the low level you might trip over, I think is easily located. And it shouldn't be any problem at all," he said.
Ann Murno tried the TekPlate out in the hallway. Again, she could clearly see each doorway.
"I was kind of amazed at how much light you got. I though it would be a little night light kind of thing. But it's a lot more than that," she said.
The TekPlate light was even visible from outside the house – a sense of safety the Murno's say they didn't have before.
TekPlates sell for 20 dollars each and run on batteries. You can order them through the TekPlate website.
- By Heather Sullivan
© Copyright 1996 - 2005 Waterman Broadcasting Corporation."
