Above: Brace of Pewter finish Minimags modified by Chop and running Lambda's MiniPro III TWOJ, 2xAA and 1xAA.
I was so tired of the dadgum Mini-Maglite after 20 years of owning and giving them away to every person in my extended family and most of my friends, that when I came to CPF a year and a half ago I couldn't get interested even in a modified one.
Even on relatively short trips abroad, I learned to take atleast 10 spare lamps and 2 spare lenses with the two MiniMags I'd pack.
I remember a bulb burning out...I replaced it and stupidly laid the damn thing on a table and it rolled off and broke the new lamp as well as the lens.
Even with fresh cells, the beam was either too bright for close up work and glared off anything that would reflect or it rapidly dimmed and being riddled with artifacts and rings was barely useful at moderate distances. Adjustable focus has always been undesirable to me. I use the tightest focus, so the rest is just an annoyance to me and something I try to avoid when twisting the light on.
I happened to be passing by the C&M B/S/T three months ago and saw that Lambda had just made it available to sign up for his new MiniPro III. I congratulate myself for my sagacity in jumping on the list and was fortunate to be #25 of the first 25 builds. Thus, I didn't have to wait too long before my MiniPro arrived.
I didn't really plan on it going into a MiniMag, I didn't know exactly what to do with it. Since I'm a chimp and have no opposeable thumbs, the most fundamental modding tasks would cause me anxiety and frustration to the point I'm sure I would be throwing poo at my neighbors.
I shipped it off to our beloved Chop and left it up to him what to do with it.
He suggested a brace of matching finish MiniMags, a 2xAA and a chop'd down and rethreaded 1xAA. That way I could swap the module back and forth. I felt a little bit of that MiniMag blah in my stomach and thought "OK, if I don't like 'em I can probably sell 'em on B/S/T to one of the guys at the ***-end of the line for a MiniPro."
Chop chose the Pewter finish for me and I really like it. I like it better than nekkid aluminum and I like that alot.
He did his usual superb work and here is what he said about the mods:
[ QUOTE ]
Just FYI, I put IMS reflectors in both of those mini mags and replaced the plastic lenses with mineral glass. I went with the IMS because the light retains its twisty function. Krolls suck, so I didn't want you to have to depend on them.
Take care,
Tony
[/ QUOTE ]
Man, it's so great to have an expert take care of stuff for ya. Our modders are a terrific resource, real craftsmen.
I turned on the 2AA and the beamspot really surprised me. I am very pleased with it. The combination of the perfectly positioned MiniPro III, IMS Reflector and Mineral Glass lens yields my favorite beamspot characteristics. I unscrewed the tail, carefully let the 2 Duracell Alkys Tony included slide into my palm, then let the MiniPro III slide out in my hand.
Below: Courtesy of Lambda, the MiniPro III:
Tony included an O-ring that can be installed to keep the module from sliding out when you change batteries, but left it uninstalled so that I could easily swap between the 2xAA and 1xAA.
I installed it in the 1xAA and fired it up. Beamspot looks about the same as with 2AA to me. The 1AA configuration is extremely ergonomic for me. I can carry the light in an underhanded or "mechanic's" grip and it is hidden in my palm. I can easily twist the bezel (with the hex shaped rubber anti-roll muzzle) the fraction of an inch to turn the light on or off. I can adjust it so that I have a momentary function as well.
Below: Beamshot from 1xAA Duracell Alky:
Below: Courtesy of Lambda, a runtime plot of 2xAA 2100mah Energizers:
Lambda's Home Page
The 1xAA has been my EDC for several days and rides just fine in a front pocket of my trousers. I could even remove the hex bezel muzzle if it bothered me, but it doesn't.
It bumped my Arc LS 3W as my EDC. No mean feat. I'm not confident of the MiniMag's water-resistance and so it won't go into the bush with me, but around town and suburbia it's superb.
Thanks Lambda and Chop for helping me get over my MiniMag aversion. /ubbthreads/images/graemlins/happy14.gif
Britt
