Hello all,
Recently, I made the decision to move up from AA M@aglite (Opalec Newbeam, Kroll tailcap modded) to something that could A)Run a KL1 4th Gen, B)Be cross-compatible with SF parts, C)Use most types of batteries I might run into (AA alkaline, NiMH, LiOn, Lithium, Pila, CR123A, R123A), and D)be as or more reliable than the Mag (a tall order, this thing is pretty great). Now, with those criteria in mind, I am looking for the ultimate package while spending the least amount of money. Several options have presented themselves, and I wanted feedback from the experts. Here they are, in no particular order:
Vital Gear FB3 body KL1 head, Pila 2X150s as primaries, 2XAA backup.
Balrog BE3 body, KL1 head, MCE2S two stage, Pila 2X150s as primaries, 3XAA backup (using DSPeck AA tube extender).
UBH Body, KL1 head, MCE2S two stage tailcap, Pila 2X150s as primaries, 3XAA backup (Using AA tube extender).
Surefire L4 tube w/CR123A tube extender, KL1 head, MCE2S two stage tailcap, Pila 2X150s as primaries, 2XAA backup.
Some questions that have arisen: First, I have heard of problems with the VG tailcap switch and battery fit, so this option seems less likely, at least until the bugs are fixed. Second, will 2 AA be enough to run the KL1 for any useful length of time? What about 3 AA? The ability to use any battery that I can find is a *HUGE* part of this project. Finally, to segeue, the MCE2S switch should allow for weaker batteries to run the KL1, correct? With this in mind, what resistor setting will work over the *entire* range of battery options to give the longest life with AA?
Right now, from my perspective the Balrog is in the lead, because it can take the 3XAA. The UBH can as well, but I have not seen the finish or workmanship on this yet, so cannot comment. The only disadvantage to the BE3 is availibility, I have yet to succeed in contacting Balrog. So, please by all means critique my ideas, and thanks.
D-R
D-R
