[ QUOTE ]
KevinL said:
Actually I like the simplicity of resistors when I have a constant-voltage supply that is not subject to massive fluctations (as opposed to automotive 12V systems). If the aircraft can already regulate power reasonably well, a resistor should work ok. A desk lamp I designed for fixed voltage input works great with a resistor, whether I'm driving it off a 5V feed tapped from a computer, 5V wallwart, or as a last resort, 4.8V NiMH battery pack (dimmer, but that's meant to be a power failure light, not its main power supply).
[/ QUOTE ]
Actually, aircraft power buses are subject to fluctuations and significant pulses, in addition to lightning hits. In fact, depending on the category you certify the equipment to, you have to take 60V to 100V hits on the bus, as well as thousands of volts of static, and various other things. In an aircraft, the buses often see subtantial pulses when switching between generators.
I've been working on military, commercial, and private aviation electronics (Avionics) for 18 years, and have seen alot of failed equipment from stuff just like this. I don't work on exterior lighting though, maybe the requirements are alot lower for exterior lighting vs. Avionics that the pilot utilizes to fly the plane with.
However, I do remember a certain master lights panel in the A6E Intruder and EA-6B Prowler that used to get blown *alot* due to fluctuations in the aircraft power bus...
Though, when thinking about it further, if you design it to fail, then there is more money in your pocket from replacement when it fails...
