[ QUOTE ]
ssteven1 said:
I am thinking of putting a nextgen 750 in a minimag with a ims 17 reflector. I read a post that stated anything over 500ma would overwhelm a small reflector. What does this mean? Also has anybody put a nextgen 750 in a minimag yet if so, how do you like it runtime ect.
[/ QUOTE ]
They might have meant that there are diminishing returns for increased drive current. This is the case in all lights, but more pronounced in smaller reflectors due to more light lost in spill. It is also generally true that smaller reflectors will be in smaller heads that are less able to sink or dissipate heat.
General guidelines are that anything over 500mA in a 17mm reflector will generate much more heat without much of a useful/noticeable increase in brightness. A McR-27 (McGizmo custom 27mm) will produce a brighter hotspot that will benefit from increased current, where the recommended max current is 750, but up to 1000 has reasonable returns.
Found the post: Bolded relevant portion of my answer above.
If that doesn't help, you could link to the
post in question, as there might be relevant context.
