3 or 4 gallons per minute at 2000-3000 psi are about where it's at.
I am in this business.
What I will tell you is this. The primary consideration when you buy is the type of pump... not the lowest price.
Stay away from the axial pumps with the head on the end away from or under the engine! They are built for home use and do so okay, but they don't like to sit unused very long.
A direct drive crankshaft driven pump with the head at 90 degrees to the crankshaft is a FAR better animal that can usually be serviced easily.
You can't go far wrong with any engine choice. We get very good service out of Briggs & Stratton engines, and Honda engines only just became common on the brand of hot water units we sell.
The Honda GX340 is a very nearly bullet proof unit however!
Look for Comet, AR, or General pumps. Stay away from Cat! If the Cat ever needs parts, you could buy a new Comet just as cheaply!
Consider what you've paid for this advice, and act accordingly!
