Re: How many HS\'s for Tri - LuxIII ??
I also noticed that the EL heatsink doesn't fit C-cell Mags.
The C-Cell is an interesting beast, because when you look down into the head without the reflector installed, it looks like the diameter is the same all the way till you hit the bottom (the beginning of the threads). It looks like 48mm to me, but someone with digital calipers would be in a better position to measure it.
Fabricating a heatsink would simply involve chopping a rod of 48mm diameter aluminium to the correct height to seat stars and their SO20XA reflectors, and boring a hole in the center for the wires to go through. I estimate this to be around 10-15mm thick. No fancy machine work, the trick would be in the measuring of the diameter and the height, then finding suitable bar stock and lopping it off.
Hotbeam, would you be interested in doing anything like this? I'm lathe-challenged and thus not in a position to build one for myself. I think the rest of the folks here might be interested.
I spoke to Kiu about his tri-sink, and he mentioned that no future plans for D-cell tri-sinks exist (or I'd have bought one on the spot, instead I chose to buy two Turbosinks to play with). He also mentioned that thermal management in a C-cell might be tricky, but I think with this kind of heatsink it shouldn't be a problem. It uses the head directly as a heatsink.
My game plan is to get 3 T_0K stars and slap them on the aluminium followed by SO20XAs (17's spread the beam a little too much for my taste), direct drive off 3 NiMH for a wicked sick amount of light in a tiny little formfactor. 4500mAH NiMHs should provide 90 minutes of partying, on top of that!
