It's pretty close! The drawings are in this PDF:
FraenSRL FHS data sheet
There are four disctinct lens paterns available: Narrow, Medium, Wide, and Eliptical.
The current SO27XA is 1mm larger in diameter at the top of the optic, and from tip-to-tip is 19.27mm high (bottom of standoff leg to rim of reflector). It seems that the batwing Fraen FHS optic is built to sit directly on the luxeon and is 19.25mm high tip-to-tip, but I believe we have Lambertian LuxIII's which would use the 18.76mm optic plus the 4mm ring spacer. This would put the tip-to-tip height near 22mm which may require some work to get in there.
I might pick some of these up to play with, they are available at Future Electronincs as is the original SO27XA.
