Jetbeam
Page 1 of 2 12 LastLast
Results 1 to 30 of 52
Thread: the Thor 15 Mcp light
    Default the Thor 15 Mcp light
    Well I see the new Thor 15MCp is on there website. Im not aware of any retailers carring it. Anyone have any new info on it. It looks alot like the 10Mcp version. Wonder if its running a true 100w?
    http://www.cyclopssolutions.com/inde...amp;itemid=164
    Flashaholic StEaLtH_'s Avatar
    Apr 2004
    The Netherlands
    Default Re: the Thor 15 Mcp light
    Looks likes it's just a bigger and deeper reflector.
    Aug 2004
    Bayou State
    I saw it on the cyclops solutions sight about a week ago, but I also couldn't find any info on it. The body looks the same as the Thor-X, but the reflector is much bigger... maybe 10, or 11 inches!
    Flashaholic* MaxaBaker's Avatar
    Dec 2004
    South Jersey
    Bigger reflector=Bigger Badder Thor!!! [img]/ubbthreads/images/graemlins/buttrock.gif[/img]
    I was thinking if it ran a true 100w with a larger reflector, would that be like the mod kit available on this site?
    Aug 2004
    Bayou State
    No...the mod kit boosts the battery voltage to 15, or 16 volts which overdrives the bulb to the brink of flashing... If you get the mod... you had better get a couple more bulbs! (just in case)
    *Retired* NewBie's Avatar
    Feb 2004
    Oregon- United States of America
    Actually, I've ran the same bulb through dozens of discharges so far, and have yet to burn out the filament in the 2X version of the mod, which is a regulated 15V with soft start. In reality, it is only a 20% overdrive, power wise. The bulb in a stock THOR is actually 20% underdriven in moments (and is never properly driven to spec), then it just heads out to pasture over the next 40 minutes.
    In otherwords, it's a sleeper or a wolf in sheep's clothing.
    The 3X Mod which I'm not going to sell, but you can alter the board at your own risk, will take it to 16V, will flash bulbs.
    Aug 2004
    Bayou State
    Newbie,
    knowing myself... I would be popping bulbs, trying to see how far I could push it [img]/ubbthreads/images/graemlins/smile.gif[/img] (just a little bit more...POP...damn)
    Flashaholic Skibane's Avatar
    Nov 2002
    San Antonio
    [ QUOTE ]
    [/ QUOTE ]
    Apparently, the only change from the 10 MCP version is a larger reflector. The bulb and batteries are probably the same, so it's still going to be rather inefficient in factory trim (13.2 volt bulb only being driven at approx. 12 volts).
    BTW, I don't see any reason why you couldn't use NewBie's booster design in this new model. With the increased case size, there should be plenty of room inside for the booster board!
    Oct 2003
    the dairy state
    WOW! nice reflector, perfect for an HID mod. [img]/ubbthreads/images/graemlins/happy14.gif[/img]
    Nov 2003
    UK
    Will it really run for an hour on one charge? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
    Jun 2003
    Portland Oregon
    is it for sale any where yet ?
    *Flashaholic*
    Dec 2003
    USA
    has any tried those philips H4 bulbs that claim 20% increase in output?
    Nov 2003
    UK
    [ QUOTE ]
    [/ QUOTE ]
    I have these in my car - they are not actually brighter, but the light is 'whiter' so they appear brighter.
    I also have one in a similar 5m CP spotlight
    Feb 2004
    The bulb in the THOR is already way above those Sylvannia XtraVision +80% types. There is only one bulb that I've tested that has higher output, and that is a Narva, which is made by Phillips anyhow, and it is only minimally better.
    Look in my THOR information thread.
    Nov 2002
    San Antonio
    Looks like they just tacked a black plastic extension on the end of the existing enclosure.
    Can a "50 Million Candlepower" 18-inch model be far off? [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Oct 2003
    the dairy state
    Still, a very nice size reflector.
    dg,
    no, this light will not run for one hour, but an HID mod will let it run for nearly 2 hours. Stupid bright, stupid long, a very nice combo. Newbie's mod would make it insane bright, which for a CPF member is even better.
    Jun 2003
    Portland Oregon
    it must have a bigger battery to run 60 minutes
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    I see NorthernTool has them listed on line now but no picture or specs $79.99
    Kelly
    Jun 2003
    Portland Oregon
    I can not find one on NorthernTool website
    Aug 2003
    North Carolina
    Well it was there yesterday but I can't find it now [img]/ubbthreads/images/graemlins/confused.gif[/img] www.northerntool.com if I find it again I will update my post.
    Later
    Kelly
    Ok, now someone has to buy one and compare it to the 10Mcp Thor.
    Jun 2003
    Portland Oregon
    I would buy one if I could
    as soon as a web site or store has one for sale
    I will buy one.
    Aug 2003
    North Carolina
    Here is the link to what I found the other day it's on their industrial site, still no pic. I see they have put the 10 MCP Thor on sale again for $39.95.
    Later
    Kelly
    Jun 2003
    Portland Oregon
    I get an eror message when I click on buy
    Jun 2003
    Portland Oregon
    does any one know where you can actually buy a 15 mcp thor ?
    Dec 2004
    South Jersey
    Nope.....but I plan on getting one.
    Jun 2003
    Portland Oregon
    I emaild cyclops solutions
    the 15 mcp spotlight will be available in march
    Dec 2004
    South Jersey
    Damn, that's a long time. O' well......... [img]/ubbthreads/images/graemlins/popcorn.gif[/img]
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    did you find out any more info from them? is it just a bigger reflector?
