Re: Good News - CBP 1650 NiMH\'s
[ QUOTE ]
Dukester said:
[ QUOTE ]
js said:
Wilkey,
With the shrink wrap still on, the diameter is .565" and the length is 1.941". The shrink wrap is of a similar thickness to the wrap on a KAN 1800 4/5A.
[/ QUOTE ]
Got the same measurements with the shrink wrap. At least we are consistant...
[/ QUOTE ]
This is so annoying/frustrating. I had more than one e-mail to Mike about this issue, pointing out the fact that most of the newer higher capacity 2300ma+ consumer cells were getting these higher capacities by increasing the diameter of the cells, with concurrent reduction of ability to supply higher current loading. Seems this cell is taking the same route as far as increasing capacity, but this is a huge jump in size compared to all of the other AA's listed on CBP's site as being 0.55in in diameter.
FYI, metric conversion:
1. 0.55in = 13.97mm, very easy fit into D-cell body 4 across.
2. 0.56in = 14.224mm or about the same that waion measured for the new Sanyo 2500ma AA's he obtained (waion is in Hong Kong, so what gets shipped to the USA could be different). Tight fit in some M*g D-cells, but should fit most as my inaccurate calipers show the tight fitting Lenmar NoMem Pro 2300ma at 14.25, while the same measure on the Energizer 2300ma will not fit in
my M*g2D, YMMV. See waion's post#812362 in fivemega's GB thread:
2nd Run 9.6 Volt UnRegulated 8AA to 2D adapter
3. 0.565in = 14.3
51; 14.30mm is almost not possible to fit, so barring lucky people who have bigger inside diameter M*gD-cell bodies, these cannot fit 4 across /ubbthreads/images/graemlins/frown.gif. Boring out the M*g body for that extra 0.05+mm is an expensive solution.
