Re: So,, Who is going to make a production LS AAA
[ QUOTE ]
cratz2 said:
Just for the record, my LED_ASAP modded ARC AAA is set at 400 mA and it runs for over 1.5 hours with an NiMH battery. I don't know how the output compares to the higher biased LS lights (like the 750 mA) but it is very usable light that obviously completely blows away the original ARC AAA and the single HP Peak lights.
[/ QUOTE ]
[ QUOTE ]
Hookd_On_Photons said:
[ QUOTE ]
LitFuse said:
I don't think you'll ever see a "production" light in that combination, at least not that's targeted at the masses. The runtime is far too short for it to be a viable consumer item.
[/ QUOTE ]
this_is_nascar has posted some runtime graphs for his Arc AAA modded by LED_ASAP with a Lux3 (I believe it was a TX1J bin, set to draw 200mA from the battery). He gets over 5 hours of runtime with a lithium AAA (just a bit longer than you'd get with a stock Arc AAA and an alkaline battery). The runtime to 50% brightness with an alkaline battery was about 2.5 hours (with a couple more hours in moon mode).
Here's his runtime graph comparing a stock Arc AAA to the LED_ASAP mod, using alkaline and lithium AAA batteries:
And here's the original thread I "borrowed" the graph from:
Now Testing Energizer E2 AAA Lithiums
I have one of these mods, set to draw about 500 mA from the battery. It is plenty bright, but it's a flood rather than a spot. It won't impress anybody who wants a retina-scorching spot that throws 100 yards. However, it's an excellent close-range (30 feet or less) illuminator.
I think an inexpensive Luxeon AA or AAA light would be quite appealing to non-flashaholics. My wife doesn't understand flashaholism, but she was very impressed by the Luxeon Arc AAA mod on her keychain.
At the current levels used by these small lights, there shouldn't be much difference in brightness between cheap Lux Is and more expensive Lux IIIs, though the Lux IIIs have better tint. Judging from the other mass-produced Luxeon products out there, I suspect that a line of consumer-grade production Lux I keychain lights will have a relatively high proportion of greenies.
[/ QUOTE ]
I stand corrected, I didn't realize that this was possible. Hopefully, this will teach me not to make bold proclamations about subjects that I don't have first hand experience with. /ubbthreads/images/graemlins/blush.gif
Peter
