how may amps is rated the original bulb?
you can try the Strion bulb (1,7amp) with 3 ni-mh "C" cell but i think the increase of light is low (flashlightsreviews have measured 33,5 for the TT 3C and 50 with the Strion)
for a big increase of output you must use 6 ni-mh 1/2 "C" batteries, with this configuration you can use many Welch Allyn lamps:
WA01123 at 2,2amp for 50 hours at 350 lumens
WA01148 at 2,1amp for 20 hours at 440 lumens
WA01164 at 3,6amp for 200 hours at 600 lumens
WA01219 at 1,2amp for 100 hours at 140 lumens
WA01274 at 2,7amp for 40 hours at 550 lumens
WA01315 at 1,5amp for 20 hours at 300 lumens
for hours i intend lamp life and for lumens i don't consider the reflector and glass losses.
only for this bulbs i think you must enlarge a bit the hole of the reflector at 7,1 mm
i don't know but if the reflector is plastic (like my 1L) you can't use the bulbs with too amps for not blow the plastic, i hope is aluminium
