It appears that most flashlights require the battery to be oriented with the positive end toward the bulb or LED. The Pila lights with LED tailcaps require the positive end to be toward the LED, which would seem backward. Thus a general rule would seem to be that if a LED is used, then the positive end goes toward it. Then there is the situation when a converter is used, which seems to also require the positive end of the battery going toward it. Is this a reasonable general rule to follow, or are there exceptions to these in some lights?
