Wuben
Results 1 to 5 of 5
Thread: X990 Charger
    Default X990 Charger
    Is the stock charger that comes with this light a 'smart charger' or is the battery a 'smart battery'?
    [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Flashaholic pyro's Avatar
    Aug 2003
    Germany
    Default Re: X990 Charger
    it is a 'smart battery'
    however, i had one of my two packs going bad.
    heard a little crack while it was charging [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Jun 2003
    Portland Oregon
    the pack of cells has spot welded tabs to connect the cells.
    maybe one of the spot welds came loose on a cell.
    Aug 2003
    Germany
    Unfortunately it's not that easy.
    At least one cell is leaking,
    some more may be damaged already.
    Jun 2003
    Portland Oregon
    I was hoping that it would be a simple fix.
    how new is the light ? contact the manufacturer and complain.
    does it have a thermal switch or sensor(temp sensitive diode ?) to end the charge cycle ?
    maybe one cell has a pressure switch.
    if the pack is pretty new I would remove the obvious bad cells.
    then re connect the remaining cells into a pack.
    using a power supply and a sutible load I would charge/discharge the pack a couple of times.
    then after a recharge I would put the cells under a 3 amp load .
    after ten minutes or so I would measure the voltage of the cells(while under load) any cells that show a signifigant
    low voltage are bad.
    then I would buy new cells to replace the bad ones.
    I bet the cells were not that closely capacity matched when new.
    I think new 4.5 ah cells are a little over 3 bucks each.
    at that price replacing them all would be kool - if they came with tabs.
    button tops may not fit well into the battery case.
