Everett
- Joined
- Sep 30, 2004
- Messages
- 177
i had this idea after i modded my solitaire but had problems making the switch mechanism work. this way would keep mag's original switch.
a 5mm led is plugged in where the bulb is (and the reflector bored out). the spring, spare bulb, and metal piece are removed from the tailcap (there really is a LOT of room in there). a voltage boost circuit is put into the form of a cylinder with springs on the ends (outlined in red). the threads on the tailcap must be scraped to make contact with the body tube.
i was about to start this one when i realized that the modified dorcy circuit i've been using can't just be put in series with the battery and the LED. is there a boost circuit that can?
here's the circuit i've been using. to put it in this way, i'd need to run a wire up inside next to the battery, and there's not much room.
does anybody know of a way to do it?
