WildRice
OK, for starters, I got some 1W cyan emitters off ebay a while ago. I put 1 in a 3AAA flashlight. I have been wanting to put 1 in a dorcy AAA, but the emitters are low dome and dont work well with any cut down optics, and a reflector would be too small. SO I modded the LED. I sanded and polished the surface of the emitter to make it flat. I then took an old 10mm red LED and cut it right at the piont where the die was, then I sanded it flat and polished it. I also used some pc board to make a base for it.
I then used clear epoxy to glue the dome of the 10mm LED on top of the flattened emitter.
Running at about 30mA you can see how the emitter die is focused.
All the components mounted together. After I took this I potted the lower pard with epoxy mixed with thermal compound to help with the heat.
This is powered DD from 3x 1/4AAA NiCd 110mAH batteries.
With the batteries fresh off the charger, it was pulling 500mA. This is next to my other modded dorcy AAA with a 20,000mcd led (about twice as bright as a stock).
I was not concerned with runtime, I just wanted to see if it would work. Most of the light seems to come out the front, very little from the back.
Jeff
Jeff
