I have bought a couple of the 3w "Luxeon" lamps.
Can anybody tell me where the resistor is to reduce the forward voltage? Is the body used as the resistor? By my calcs I would expect a resistor of appx 1 ohm to reduce the voltage to 3.7 volts? From 4.08V running at 700 mA.
I also tried increasing the voltage form 4.08V to 5.47V (4 rechargables) The LED brightness increased. Then tried 6.45V - Blew the LED!!! Should have checked the calcs before experimenting....
With 550 mAh AAA batteries I am getting appx 1Hr "bright" run time. Not quite sure how this works....
I=V/R therefore:-
I=4.08/(0.8+1.142)= 2.21A -Dynamic Resistance of LED + "resistor".
With 550 mAh batteries this should give a run time of 0.55/2.21 = 15 minutes run time !!!!
Could somebody check/correct my calcs???
I will now check the actual run times on my new 850 mAh AAA batteries.
Thanks For any help.
I=V/R therefore:-
