Thanks for the positive reactions and for adding it to the LED-Museum links! I used Visual Basic 6.0 for the program. I stole the formulas from a German forum, this is what I found:
Lumen = Candela * Steradian
Steradian = 2 * PI (1 - cos ( PI / 360 * half angle))
These formula's calculate the whole thing. The efficacy (never heard of that word before, what's the difference?) is derived from that with the help of Ohm's law.
The formula's should be correct in theory, but since intensity varies over angle, I'm not sure it's really accurate, for some LEDs it will be, for some others it won't.
[ QUOTE ]
IsaacHayes said:
Benadski: sorry to go off topic, but your signature, is it talking about the "UFO" luxeon clones in UV? If so could you make a post about them! I've bene wondering if they were any good for a long time and not many people noticed they were avalible in UV.
[/ QUOTE ]
I've just got these hooked up, there bright! Only it's hard to compare them with normal UV LEDs because the wavelength is near the edge of what my eyeballs see. I think it puts out about the same as 8 to 12 normal UV LEDs.
I've noticed they are a bit hard to get. Roithner is the only supplier I found that has UV as well as IR in 1W UFO. I have the 405nm 30 deg. 11mm with M3 thread by the way.
You might have noticed Roithner has some more interesting UFO's, there is even a RGB UFO available! Too bad the light output of this sucker is VERY BAD! I hope Lumiled will make a slightly diffused RGB someday, that would kick ***!!!
