Fenix Outfitters
Page 1 of 7 1234567 LastLast
Results 1 to 30 of 192
Thread: Q3 Rechargable!! - The Q3-R Forum :)
    Flashaholic* CroMAGnet's Avatar
    Sep 2004
    Los Gatos, CA
    Default Q3 Rechargable!! - The Q3-R Forum :)
    Ok! I just received my new rechargable R123 Battery from BatteryStation and popped it into my Q3. Loox like it came fully charged.
    I also ordered a few extra 123s for my [other lights] so I put in a fresh 123 and put it directly on my light meter. it measured 900,000 LUX (not at 1-meter) Then I put in the rechargable and it came in at 1,650,000 LUX (not at 1-meter) Then I took the square root of each (like quickbeam's formula but mot at 1-meter) and the numbers came to be 30 and 40 respectively.
    All this mean's is that the Q3 with rechargable batteries to start has at least 33% more output. Am I missing something?
    I didn't get any instructions with my new charger and battery. Does anyone know how long it takes to charge? Are there any other precautions I should take or do while using this charger/battery?
    This has probably already been discussed but just wanted to throw up this first impression of the rechargables and Q3.
    Thanks for looking [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Flashaholic* chevrofreak's Avatar
    May 2004
    Billings, Montana, USA
    Default Re: Q3 Rechargable!!
    Looks can be decieving. When my JSB-123's arrived they had some juice in them, and tested at something like 3.4 volts, but they still took about 5 hours each to charge.
    When fully charged my JSB's were 3.85 volts, and didnt blow my TM-301X-3. I got 23 minutes of tremendous brightness, and the head got HOT! I guess that should be expected when feeding a light 7.7 volts rather than 6 :P
    Sep 2004
    Los Gatos, CA
    Need to do this a little more accurately just to make sure. Amazing thing is the numbers I got using the regular battery in the Q3 are exactly the same as Quickbeam's review!!
    Standard CR123 600 LUX @ 1-meter
    BatteryStation Rechargable R123 990 LUX at 1-meter
    Estimated non-scientific results while applying the inverse square law, used by Quickbeam;
    Standard CR123 24.49 meters of throwing power
    Rechargable R123 31.46 meters of throwing power
    That's 28% more throwing power and since we are using the same light we can assume that the Output has also increase 28% (I'll test that with Gadget_Lover's 'bird cooker' when we get together in February if I remember) In fact that might help corralate accuracy of the cooker...
    May 2004
    That is a very healthy boost indeed!
    Flashaholic CPFMan's Avatar
    Dec 2004
    Earth, Solar System, MWG
    That's quite exciting indeed. With the extra boost, will it hurt Q3 in the long term? How about led, is it overtaxing it?
    [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Flashaholic Freedom1955's Avatar
    Nov 2004
    Michigan
    [ QUOTE ]
    I'm wondering the same thing.
    [/ QUOTE ]
    nice! i just bought some rechargables...i cant wait!
    Sep 2003
    Cali
    I just got my charger today. It'd not the one pictured on the Battery station website though. It a black two port one. My battery appeared to be fully charged. I'm still waiting on a spare battery.
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    CromagNet: if you want even more zing from your Q3, pop in a 20mm IMS reflector. It's not orange peel, but will throw farther!
    Isaac, where do we go about getting one of these reflectors?
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello CromagNet,
    I think part of the increase is that primary 123 cells have a voltage of 3 volts where rechargeable 123's have a voltage of 3.7 volts.
    Tom
    Sep 2004
    Los Gatos, CA
    Hey thanks everyone for all the tips.
    Isaac: I really like tho OP and not looking for more throw. I like the higher output and white white white! (with a teeeny bit of blue) My Ombu still has more umff all around. But the reflector idea you mentioned would definately get more throw and output. which many other will want to do [img]/ubbthreads/images/graemlins/smile.gif[/img]
    SilverFox... Thanks for all your help as I was learning about this one. I am really pleased with it. Now if I can just do the same thing for my Ombu [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Enlightened OZ's Avatar
    Dec 2003
    Maui, Hawaii
    [ QUOTE ]
    [/ QUOTE ]
    I got the same one today as you did AR15Fan. I emailed Kevin @ Battery Station earlier today and asked if it had the same properties as the one pictured on his site.
    Sep 2004
    Los Gatos, CA
    HEY! Now that you mention it. That's what I got too. Let us know if anyone finds out differences.
    Unenlightened Nanook's Avatar
    Mar 2004
    LA, CA
    That's funny. I just received the same two port charger today as well. We must have had a "4:20" moment of ordering rechargeables. My charger didn't come with instructions either, but the back of it says "charge with constant current and constant voltage" so I wonder if it has a trickle charge and is safe to leave batteries in it for long.
    While I don't have a light meter, I am thrilled with the apparent increase of guilt free output. I hastily took one of the two batteries and stuck it in my Q3, but the other one measured about 3.8V fresh off its first charge.
    [Edit] On its second charge, it measured 4.04V.
    On a side note, I finally managed to get the head off to check my bin (SX1L) by leaving it on for about 5 minutes. Got pretty toasty!
    I'll watch this thread for further news, rather than sending a duplicate email.
    Does any one have pics of the two port charger?
    How much time does it take to fully charge a R123?
    Can you charge one cell at a time?
    Do the R123 heat up when left too long on the charger?
    How many cycles do you get from these R123s in this two port charger?
    How does this two port charger compare to the competition?
    Oct 2002
    Fresno, California
    Funny, I got the same charger on the same day. What is not funny is that mine also came with no instructions whatsoever. This is more than a little disheartening considering all the precautions I hear about rechargeable lithium ions and I am a relative newbie at this.
    In defense of the Battery Station, it did arrive quickly and came with a home and car adpater. They even gave me a pen and a calendar.
    May 2004
    With protected batteries, they shut off internally when they get full, so the charger could probably be left on indefinately.
    Very interesting that these are testing at 3.8 volts for a 3.7 volt cell, and my JSB-123's test at 3.85 volts for a "3v nominal" cell....
    Dec 2003
    Maui, Hawaii
    I just got a email reply from Kevin @ Battery Station, regarding the new chargers here's what he wrote:
    "Yes, it is a better charger but not updated picture yet. The smart part is really in the battery. NOT regulated but protected. Still tops at just over 4V."
    I also got the pen and calender which I thought was a good touch.
    Sep 2004
    Los Gatos, CA
    Default Re: Q3 Rechargable!! (BIG Update)
    ** OK BIG UPDATE ** I just got off the phone with Kevin at Battery station. I was trying to type exactly what he was saying as he was saying it so excuse the syntax or potential confusion...
    -- New charger does one or two at a time. Uses bi-color LED to monitor. Starts red and goes green when done. Leave it on all the time. Kevin leaves spare in there all the time for days and then just swap out. Does NOT get hot. It's a slow charge, 4-hours approx time to charge if dead. They have been testing them, so many come fully charged already. Topping at about 4.2v off the charger. They tried a regulated batteries at 300-400mAh (because of space requiring regulator in battery) Non regulated are 700mAh. They were frying under heavy current. So regulated will not work in some lights and fries the regulator. So they scrapped the regulated project. NO regulated Battery. THEY ARE PROTECTED BUT NOT REGULATED. Kevin.
    I hope I got all that write. Please correct any errors Kevin and thanks for the help [img]/ubbthreads/images/graemlins/smile.gif[/img]
    NOTE: They have been burried with a lot of end of year and new software stuff and just wanted to get product to you guys as quick as possible.
    PS Kevin said they have been using them in dual set-up lights and they worked without problem. Voltage went up from 6.6v to 7.4v making for brighter lights. So I ordered two more and am hoping it will work in my Ombu X33... I'll post here when I test :fingers crossed:
    Flashaholic WallaceD's Avatar
    Aug 2004
    United States
    So, in a nutshell, these batteries will feed a Q3 without any problems whatsoever. Right?
    How would these perform in a Micra, I wonder?...
    Oct 2002
    Fresno, California
    Thansk for the update. I seem to be having a problem with one of my betteries. One looks like it just went dead while in my Q3. When my batteries arrived I measured them at 4.0v and 3.8v. I put the 4.0v in my Q3 and have been measuring the voltage after every few minutes of use. My last measurement was 3.7v minutes before the light went out. I measured the battery and it now reads ZERO! Nada. Zilch. It does not appear to be taking charge as the red light on the charger will not come on. Great. I hope I don't have to worry about this little bomb exploding in my house. Guess I'll call Battery Station and see what they'll do. Anyone else having problems?
    Ken
    Dec 2003
    Maui, Hawaii
    KLM by looks of your photos, you might have your batteries reversed. My charger has the the negative contact towards the LED indicator.
    Try looking at yours and see if it's the same
    Sep 2004
    Los Gatos, CA
    WOW! Bummer KLM... Please keep us posted. ...
    Oct 2002
    Fresno, California
    [ QUOTE ]
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/blush.gif[/img] Yep, you are correct. Okay, that's embarrassing. After putting it in the charger CORRECTLY the battery that read 0.0 now appears to be taking a charge.
    Also, I called Battery Station about the battery that went dead and spoke to Kevin. He said that some of the batteries they tested did that when under heavy load. It's a protective board in the battery that breaks the circuit to protec the cell. Hopefully, all will be copacetic now. They really shouldn't let stupid people play with these things. [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Thanks,
    Ken
    May 2004
    [ QUOTE ]
    [/ QUOTE ]
    The X-33 is the same as my TM-301X-3, which was being pushed at 7.7 volts without any apparent problems, but pushing at 8.4 could possibly present some...... Let us know how it turns out, and expect the head to get HOT!!!!
    Sep 2004
    Los Gatos, CA
    KLM that's the good news [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Chevrofreak: Did you end up giving that to your sister? I'm wondering if it will come down to the bin. Maybe one will handle the increase and a different one wont.
    My Q3 say SYOL on it. S Flux = 51.7 to 67.2 Lumens with 635 to 755mW --- YO = 0.292 to 0.307 tint cool white [img]/ubbthreads/images/graemlins/smile.gif[/img] ---- L forward voltage Vf = 3.75 to 3.99V
    So If I'm running the Q3 at 4.2 on this bin it should be overdriving it just a bit when battery is fresh. Is that correct? will it be ok? (I'd think it would be)I'm going to boil my X-33 (brb)
    TX1K bin. The beam is white but with a bit of green/yellow compared to Q3.
    So ... T Flux = 67.2 to 87.4 Lumens with 755 to 875mW Power
    X1 tint but with Vf only 3.51 to 3.75V
    If running these rechargables in series creates 6.6v to 7.4v at 700mAh my poor little X-33 TX1K wont take the strain.
    I can't believe I just spewed this out! Wow... are those calculations correct? And what are the consequences?
    What's the bin on your X-3 Chevro?
    Flashaholic* koala's Avatar
    Mar 2003
    Melbourne, Australia
    [ QUOTE ]
    [/ QUOTE ]
    It can be much higher than you think. There is peak current in this circuit design where normal dmm will average out the current. You will need a scope to look at the peak.
    Sep 2004
    Los Gatos, CA
    Hmmm... I was just trying to run down the new rechargable battery by leaving the Q3 on. After about 5 minutes I touched it and it felt cool. After about 15 or 20 min it made a really good hand warmer. So I turned it off and took out the battery, which was not really warm.
    Nov 2003
    Philippines
    [ QUOTE ]
    [/ QUOTE ]
    Please correct me if I'm wrong. The cells are protected to prevent over-charging and over-discharging. I don't understand what you mean by regulated.
    I asked Kevin over email regarding the old charger and he said that the charger is smart so it means it should be able to charge both protected and unprotected cells as well as higher capacity cells of the future. Does this also apply to the new charger? Can anyone verify this with Kevin?
    Thanks.
